Spark plug
- Durham, England
I dont suppose the majority of people do LH threads either
Even to a professional turner, screw cutting LH threads mess with your head
I’m doing some of these for @123hotchef and I need a left hand thread in one end and a right hand thread in the other they are trackrod adjusters[/QUOTE
Well I'm glad I didn't waste money buying the taps yet. Last I knew was that I was going to make them![]()
Were you? You're more than welcome if you want to
It'll be fun repeatedly centring 30mm stainless hex 20 times in a 4jawNo, too busy now. Have fun![]()
That's how I made the others.L/H nut R/H nut machine a sleeve to length and TIG together lot easier than the ball ache of turning something from solid....
If I had one that didn't have a half thou run out I wouldIf it's hex can't you just stick it in a 3 jaw?
Can't it be fixedIf I had one that didn't have a half thou run out I would
Well you never replied to the last messages on the 20.2.19 so I guessed you were not wanting to do the job.No, too busy now. Have fun![]()
I'm going to have another mess with it next week the jaws are badly damaged so I've been filling the high side down and for general turning it does anything that needs presition goes in the four jaw but if I could get it down to a quater thou I'd use it for the job for what the parts are a half thou would be fine but I'd rather it Was lessCan't it be fixed
What is half a thou out? Have you got this figure from putting something perfectly round and straight in the chuck and taken a reading with the DTI off the end of it? If so then I’d say that 3 jaw chuck is incredibly accurate indeed. That is just over 0.01. Mine can be clocked bang on via the tapered screws but for a standard 3 jaw chuck 0.01 run out if checked properly is bloody impressive.I'm going to have another mess with it next week the jaws are badly damaged so I've been filling the high side down and for general turning it does anything that needs presition goes in the four jaw but if I could get it down to a quater thou I'd use it for the job for what the parts are a half thou would be fine but I'd rather it Was less
Drill stainless hex 150mm in length straight in a vice with a hand drill good luckI would have though that's an acceptable tolerance for this application?
If I was making them for myself I don't expect I would even use the lathe, hex would get clamped in the vice, drill one hole all the way through, tap both ends to 'about' half way through.
But the outside isnt important. If the hole is drilled through slightly on the **** it will make no difference to the application. The hole and threads will still be lined up and the outside diameters matter not.Drill stainless hex 150mm in length straight in a vice with a hand drill good luck
