mart
- South Yorks
I am planning to attempt the restoration of a headstone that has broken in to many pieces. The average size of these pieces may be only 5" diameter.
It dates from the 1800s and the material is actually stone, as opposed to granite or marble.
The first job would be to take plenty of photographs. As the gravestone is laying flat on the ground face up, the individual pieces are still in the correct position, with small gaps where the cracks are.
I would use a piece of 18mm ply with a few pieces of timber spaced across the underside of the ply to brace & prevent flexing.
Then lay the individual pieces of stone face down in posotion on the ply. Screw some pre drilled 4x2 all the way around the stone thus clamping them in a "frame"/shuttering.
Mix some quick drying concrete adding black cement colouring to this first part of the mix, in case any of the mix should permeate through the cracks towards the front side. Then, while still wet top up with enough concrete and smooth off.
Any tips advice or suggestions appreciated.
