Jelly_Sheffield
Time is an illusion. Lunchtime doubly so.
- Sheffield, UK
Type A2 protects against organic gases and vapors, eg solvents, whose boiling point exceeds +65 ° C.
An A2 filter won't give adequate protection against most of the solvents used in paints and adhesives, but does have a higher capacity than type A1 (protects against 5000ppm Vs 1000ppm contamination levels)
A1 & A2 are suitable for 2K paints unless thinned with a low-boiling solvent (bearing in mind the HSE guidance that spraying 2K indoors requires air-fed), and less volatile solvent paints (usually those with traditional drying-oil paint chemistries and long open times).
For the vast majority of solvent based 1K paints (almost all modern quick drying film-deposition chemistries), a type AX filter would be required to get full protection, with the individual filter manufacturer specifying the number of hours it will protect against different solvents.
Once spent they won't properly regenerate at room temperature and pressure, even if left for a long time.When using solvents etc they have time limits. But if you leave them for a few days they clear themselves.
If it appears to have a marked improvement when you leave them to air out, that's probably a sign that your getting fully saturated and experiencing breakthrough during use.
Whilst we call them "filters" they work on the principle of adsorption, meaning that the solvent (or other contamination) forms a weak chemical bond to the media in the filtered.
To break that bond and regenerate the media, either:
- Heat & Clear Airflow
- Heat & Vacuum
- High Pressure Dry Steam
Is required, which isn't something that a user can do to the filter cartridge.
Ultimately for proper protection during regular use, LEV and/or Air-Fed RPE is orders of materials cheaper, because filters are going to last at most a week of use, in many applications, possibly only one 8hr shift before there's a risk of breakthrough.
