Hi,
I have a cigweld 195 welder which I believe has a bad capacitor, the screw terminal on the top is broken. The problem with this welder is I cant run it at its maximum output as it will just blow the circuit breaker, I believe it may be related to the capacitor problem.
There are two capacitors which are rated at 22000uF and 63V
I have two capacitors which came from another welder that are rated at 8000MFD and 175VDC. They are much larger in size physically.
Will this work if I swap them over?
Thanks
Thanks
