Smallfry
HE's Spartacus.
- Kent UK
Not sure which section I should post this, but anyway .........
I have a big old Ford six cylinder diesel engine (590E) that was fitted to a back up generator. It was allowed to run with too much sludge in the sump, which ended up blocking the oil pickup in the sump. I imagine what happened, is that a couple of journals were more or less starved of oil, so started to heat up and seize. As the fuel pump has a governor to maintain a particular RPM, the RPM started to drop, and so the governor increased fuelling to try and maintain that RPM, compounding the problem until the engine finally seized.
The engine has only done about 600 hours, and the cylinder bores are perfect, and the crank seems OK except for the melted bearing material melted onto a couple of the journals. The bearings are Vandervell lead copper items by the look of them. I dont want to spend a lot of money on having the crank reground, because I am too tight, dont really have a use for the engine ATM (stupidly gave away the generator bit a few years ago) AND, most importantly, my machine shop of choice is now within the London ULEZ.
How can I remove this material without causing any (further) damage ? Being it is most likely lead based, or possibly aluminium, I dont think anything acidic will touch it, and if it is lead, alkaline will not do anything either. I dont really want to try abrasives, except for final polishing, so thought about using a blowlamp to hopefully melt it a bit, and brush it off with a brass or wire brush, then polish it from there.
Is using a blowlamp likely to affect the crankshaft in any way ? It is forged steel, very hefty, and I am not thinking about making it anything like red hot !
