Dieselman 63
Forklift Certified
- Wellington, New Zealand
I've seen a lot of vids on YouTube about true blind holes and how you can force wax under to get them out, but the bearings on the bottom of my lathe are proper knackered - they're just ball bearings so not the stupid-expensive ones in the headstock, so don't worry!
The outer race is trapped in the hole and I don't know how to get it out. Heat won't help as even if I heat it up, I still have no way of getting it out. I can't tap from the other side or force anything under as the hole is there.
This is inside the cast piece which holds the worm drive. The smaller hole is where the shaft runs through.
And this is the problem - the outer race stuck in place. I can't cut it, I don't dare chisel it as the cast is so thin here.
Pullers look expensive. Does anyone have any clues?
