Ian.stewart
New Member
- UK
I have a stock ESAB C201 Mig Welder, recentlyI noticed may gas consumption has rocketed, I never touch the regulator and is set around 3-5psi, when I checked was up around 50psi !! so I adjusted the pressure down to where it should be, not long after I checked the pressure again and it was up at around 20psi, reset again and got on with welding checked again and it had risen again. because Im welding thin material so its normally on a timer, Im thinking the regulator is not locking and shunting the pressure up because of the type of welding im doing, is it new regulator time??
