Screw and go, they’re a taper fitting so don’t need any additional sealant. If you get to a point where you think it needs sealant, it’s time for a new reg.
The threads aren’t meant to give you a gas tight seal, that is achieved at the seating area. Oh and the threads are parallel not tapered
To clarify, I was on about the nipple bit, not the threads. Sorry for the confusion, will be clearer next time.
ive wrapped a bit of ptfe on an argon mix reg after I dropped it and damaged the seal, allthough i wouldn't recommend it
Ive put gas seal paste on my regs when I’ve needed to. Not on the threads though, just the mating surface.
