mangocrazy
Italian V-twin nutjob
- Sheffield, UK
A while back I bought a 240v parts washer off eBay, effectively identical to the Clarke CW1D floor standing item, but painted orange instead of red. When I came to use it, I found that it need around 20 litres of solution in the tank before the fluid level was high enough for the pump inlet to draw anything other than fresh air. I regarded this as a long way from satisfactory and decided to modify the pump arrangement.
I decided to go with a 12v pump as they were a) readily available and b) less potentially harmful if I cocked anything up. The one I chose was this item:
http://www.ebay.co.uk/itm/Diesel-Fuel-Transfer-Pump-200-GPH-Refueling-12v-/370538859446
I acquired a nice chunky (110Ah) 12v battery (also off ebay) for a very reasonable £25 and tried the new arrangement out for the first time last night. It all worked beautifully, I'm glad to say, but if anything it worked too well...
The pressure the pump provides causes quite a large amount of splashback when the jet of fluid hits anything solid, and consequently a fair amount of degreasing fluid found its way onto the floor, me, adjacent walls etc.
Is there any way of reducing the pressure by means of a resistor or potentiometer in circuit, and if so how would I go about this? Some kind of variable resistor would be good, so I can dial in the amount of flow/pressure required. A self-contained unit, that I can wire into and out of would be perfect. The specs for the pump are as follows:
Connections: 1/2" (13mm) Hose
Dimensions: 165mm long x 38mm diameter
Maximum Current: 4.5 amps
Output: up to 200 gph (760 lph)
11 PSI pressure
32' (9.7m) Head
3ft (1mtr cable length)
Continuous Duty rating but should not be run dry for long periods
Actual Weight: 0.22 Kg (Approx. 0.42 Kg packed)
Any suggestions gratefully received...
11 PSI pressure
32' (9.7m) Head
