Hoping the collective can point me to some kind of washer magic emporium that stocks what I'm after as I'm hitting a wall.
I'm not totally sure what Record Vice I actually have, but I do know the washer that goes between the spring and roll pin on the spindle is bent and needs replacing (already straightened it once but its clearly weak).
Removed it and its coming up as 30mm OD, 24mm ID, 2mm thick.
Theres obviously a tiny bit of wiggle room on the measurements, and I'm willing to do a bit of fileing if its slightly undersize on the ID, but everything I've found so far is way out when it comes to the ID/OD relationship. The only washers that I can find that are bang on spec, are copper - which is obviously no good at all.
Any suggestions?
Cheers
Harry
Any suggestions?
Cheers
Harry
