sako243
- My mansion in Wales
This is my first foray into reamers - so don't have any old ones - so if I need one I have to buy it. I also bought 'cheap' as I don't know the right size (Accuracy and exerience!), and only need it for 8 (Well 16 or so if it works well) holes. Interesting idea on blunting one though - would I just treat it roughly, or with no oil ?For tight fit I use an old reamer or gently blunt one .
Accuracy isn’t a given it take time and experience
Yes, I've wondered about that, but never worked out how that could be achieved. With a really small grindstone on a dremel or similar, whilst turning in the lathe?One thing is to grind relief on the punch so there’s more shear action . With sheet material up to about 4mm this really helps
Would a bull nosed slot drill bit do it?Yes, I've wondered about that, but never worked out how that could be achieved. With a really small grindstone on a dremel or similar, whilst turning in the lathe?
- my little mill which in the same realms of rigidity as a Bridgeport et al was made MANY times worse by having a rotary table, and a chuck thrown into the mix. I know it was wrong - but didn't realise how wrong it would be.
(As I have some of supposedly each, and they are identical - at about 3.95mm.
