123hotchef
- Kent
I am after some 8mm or 10mm re bar for my BBQ grill does any one have any they want to get rid of.
Or shall I pop down to travis
I have a ton of it. Even if I was to give it away, it would work out more expensive than just buying some new.
On the other hand, if you were to pop over to W. London, you could have some (f)rebar with your cuppatea after the shed tour.
Naturally this is part of my upselling strategy. No one leaves here empty handed...
@123hotchef
6mm rebar will be good enough, the thicker stuff takes too long to get hot and sucks out too much heat from the BBQ
I’ve got a grill made of 6mm that’s been sat out side for 6 years. It’s in tip top condition
Added flavourfailing that I cut up a cage I have here and harvest that for bits! some of it is galv but it will soon burn off!
I didnt see 6mm listed at travis Parm where did you obtain yours from
I have a fair pile of pre cut lengths of the stuff. I guess postage wouldn't be that expensive if I sent you some short lengths. Save messing about with cutting and collecting. Shall I look into that. This is the pile I'm thinking...
I think that's a fairly early picture. Pretty sure that's not even half the "shorts"....
