BrokenBiker
- Newport, South Wales
time for an update.
I have put a new inner wire on now, but still have the same issue. when I took the old cable off I checked the derailleur moved freely, it does, through all 6 sprockets, the twist grip moves easily and smoothly through all 6 clicks in each direction, the inner moves very smoothly and freely in the outers, and I put a bit of oil down them too just for good measure.
now the problem. with the inner connected to the twist grip, the outers all in place and located in the stays, but not connected to the derailleur the twist grip moves fine. as soon as I connect the cable to the derailleur, take up the slack and tighten the nut down, the twist grip refuses to move at all.
I have the grip set on 6, the chain on the 6th sprocket (smallest) and have tried adjusting the barrel adjusters on both the derailleur and the twist grip and nothing makes any difference, but I can still move the derailleur with my hand easily and freely.
the only thing that I can think of is maybe the outers are the wrong way round, i.e. the one on the bars is longer than the one on the derailleur, should this be the other way round. I cant see it being that though. if I grab the end of the cable with a pair of pliers and where it runs along side the frame and pull the derailleur moves, but for some reason the twist grip wont budge unless I disconnect the cable from the derailleur.
any ideas? this is becoming more of a job than I wanted it to be now and I want to get it done and working
Careful with that, it can start to get really expensive very quickly.
