gaz1
- westyorkshire
forget the book and forget the temp when leaving the rad its makes jack all difference
if you have balanced your system right by slowing down your return feed then the return boiler pipe temp is whats needed
across the rads means nothing due to there size as a smaller rad will return faster to a larger size rad that takes longer for the water to return via the return pipe
truth in the matter is it dosnt matter as those radiators start to heat up more and more from cold then the flowing temp will slowly start to hit the return temp on the boiler the longer the system is turned on
this is what happens when you have a woodstove or a coal burning back boiler as it dosnt shut down
