gaz1
- westyorkshire
you still dont get it
when you have equaled both the rads first and then you equalised the cylinder then you can run both at the same time
its when the cylinder is sent direct path open it will cause the rads to stay cold similar to the rads that take the quickest run when just feeding the 4 rads via the first video
if you want the cylinder to warm first before you get up then you can do so using a dual timer one for central heating the other for the hot cylinder just have it on 1/2 hr before direct to rads for get up times in a morning twice daily is normally enough for a well insulated cylinder 3/4of an hr being the optimum for a full tank of hot water
for those systems that are run both then with them being set equalised then you can run the system as normal rad and cylinder and the system will heat well enough during that time until the cylinder stat closes the valve to the cylinder
