I was looking at these Vapour blasters for a mate of mine who's into Motorcycle restoration.
He was questioning this statement.
"As standard the machine is fitted with a 8mm Boron nozzle, this means you can run the machine from a small shop compressor of 7.5CFM or more, you can reduce the air requirement further by fitting a 6mm nozzle if need be. This will mean parts take slightly longer to clean however."
Not knowing much about vapor blasting I thought I would ask you. I do know I need 80cfm to get 50psi out of an 8mm nozzle when dry blasting.
