G'Day all, I am about to start build a new steel shed on my property and would like a power meter in the sub-board to keep track of how much power I am using on the 3 phase circuit, mainly for curiosity purposes. I am looking at several meters but the specs are a bit foreign to me, for the record I will not be doing the wiring, I am just buying all the bits so after the earthworks are finished I can get the sparky to proceed without waiting for all the parts.
The power supply over where I am is 234-240V single phase 50hz and when combined it ends up about 415V 3 Phase. The thing is that most of these units here are slightly different and my sparky is on holidays for the next month. The specs in question are as follows:
3x5(80)A
3x5(100)A I assume that the "set" and "turn" have something to do with the RS-485 interface (which I don't need)
3x5(100)A
3x10(60)A
3x20(80)A
The biggest welder I have is a 27Kva unit, but as I don't run it anywhere near its full power, I will assume it will use less than half of its rated max draw. So what do the specs mean, just trying to work out which one to get! The cable to the shed is 25mm 4C+E and the shed will have a 40A main circuit breaker. The cable is way overkill but it came up much cheaper than the 16mm I had intended to buy, looking on the bright side there will be no voltage drop, the welder runs quite happily on a 32A MCB. Any thoughts or recommendations on these meters?
Cheers
Ed.
3x5(80)A
3x5(100)A
3x10(60)A
3x20(80)A
Cheers
Ed.
