I have just bought a ML7 lathe but the tailstock barrel is stuck solid. I have soaked it in penetrating fluid but it doesn't want to move. I think the problem lies with the barrel clamp.
From looking at the poor diagram in the manual I'm guessing it has 2 halves, one with a threaded rod coming from it which passes through the other half. On the other end of the threaded rod there is a chrome lever that you tighten to pull the 2 halves together and clamp the barrel.
Am I correct in the way it works? I have got the half that connects to the threaded rod loosened but the other half is stuck solid in the body of the tailstock. Can any of you that have Myfords check if this should be loose?
I tried to move it with a punch but no joy. I am tempted to try heat but I'm scared I could do damage.
I spent ages tidying them up using a needle file and a hacksaw blade but I have it running smoothly.
Pillock.
