mtt.tr
- Essex/Suffolk border
How rough, using a scaffold tube on a ratchet. A true professional would use a power bar and a longer scaffold tube!
**** or bust also broke my 3/4 breaker. It's why I bought a multiplier
This really annoys me,Expert level is linking two spanners together!
Not much winds me up as much as that!!
I don’t do that at all![]()
I must be expert thenExpert level is linking two spanners together!
yeah that's rough asThis really annoys me,
But true expert is using a chisel on large nuts
If I do anything hub related I order a nut before hand.
This is going to be a slightly controversial statement. But can save you money especially if you mainly work on older cars.
Good quality sae sockets and spanner’s can be used on their metric equivalent fasteners. Meaning you only have to fill in the gaps with metric spanner’s instead of a full set. You can go the other way as well but in my experience sae tends to work better on metric fasteners than metric on sae. The sae are generally slightly smaller a then the equivalent metric fastener, so ounce the tolerance on the fitting and spanner are taken into account means they will fit snugly on metric fittings. I know in a perfect world we would have an exact set of everything but dosent always work unfortunately, especially handy in portable kits as can save a lot of space a weight if both are needed. Most of the larger sizes 25mm plus bar 30mm are just direct equivalent of each other.
There is going to be trouble, look what I have found:
Wrenches for Professionals and DIY Enthusiasts
Lightweight wrenches from ASAHI: up to 30% weight reduction thanks to clever cutouts – ideal for overhead work & daily tool use.www.fine-tools.com
And I really like this idea:
Assembly Tools - Buy Online - Fast Shipping
Assembly tools for the workshop or DIY enthusiasts, available for online purchase with fast shippingwww.fine-tools.com
Pic for those that don't click:
Yeah I did that . . .Same philosophy here. If it's a tool I know I'll use at some point in time, I'd rather buy it when I can afford it, & have it sat there, than wait until I need it, & risk either not being able to afford it, else be stuck for doing the job until it arrives. Plus, I am a bit of a tool whore.
It's like the old saying: Better to have & not need, than to need & not have.
Once bought, they cost nothing other than space.
I'll second thatCall me old fashioned, but I can't bear to use any adjustable that isn't a Bahco. Every single other adjustable seems to wear out faster, slip off nuts faster, and generally be a pain.
Bahcos aren't even that expensive these days. They're not quite as good as they used to be, but they're still very good.
Thing is, if you have all the gear, long spanners, power bars etc, then you probably don't need cheap ratchets... but that's all you have, then they really should be able to take some abuse.
I avoid adjustables unless It is something I know is loose. I don't have any but Lobster are apparently very good, not sure in comparison to Bahco.Call me old fashioned, but I can't bear to use any adjustable that isn't a Bahco. Every single other adjustable seems to wear out faster, slip off nuts faster, and generally be a pain.
When I were a lad, long before @Robbie260 was a semen stain, I went to sea. It was an old ship pre hydraulic tensioned heads, xheads etc. Every nut was done with either just a hammer, or a hammer and flogger. Only thing that was hi tech was a special head socket as you couldnt get in to swing the hammer. This was a great big socket, welded to an extension with a 2m T bar. The correct torque was achieved with two men-according to the book.This really annoys me,
Still have a emergency slogging spannner on the wartzila engines.When I were a lad, long before @Robbie260 was a semen stain, I went to sea. It was an old ship pre hydraulic tensioned heads, xheads etc. Every nut was done with either just a hammer, or a hammer and flogger. Only thing that was hi tech was a special head socket as you couldnt get in to swing the hammer. This was a great big socket, welded to an extension with a 2m T bar. The correct torque was achieved with two men-according to the book.
We only resorted to the chisel when the heads were too mashed to use just a hammer. Then we just used to split them!
