Brad93
- Essex, United Kingdom
That looks like the most complicated slowest way to do that job in the world
2nd that, dump the bale in a feed ring ,little waste, what he did just gets trampled into the ground.That looks like the most complicated slowest way to do that job in the world
- and the 'spreading', isn't - it's more 'dropping'.
Excuse me?but many women wouldn't be confident or able to drive a suitable tractor.
Excuse me?
I think she'd be turning in her grave with a comment like that
Plenty of ring feeders here buddy, though also very common to have round bales fed out across a paddock, and you're right that the feed isn't wasted. Probably more waste off a ring feeder where it's trampled around the edge.Looking at the setup its in newzeNew Ze where they dont use ring feeders
Also the way it leaves blocks across the field means you get several animals around each block it increases the surface area for stock to graze whilst reducing wasteage its the same as how pellet snackers work and is a well proven idea that quad setup amd similar behind tractors is on every sheep and beef farm in newzeaNew
Some design changes might work. Wider wheelbase plus better ground clearance - which I'm sure would be possible with a tweak here or there, without compromising the ability to pick up the bale in the first place. I don't think most ATV bale movers would be safe to use on a side slope.I wouldnt be wanting to use it on steep wet ground for sure
