You can fit a push pull torch to anything, as long as the motor in the gun is the same voltage as the drive motor in the machine you connect it to it can be made to work. I normally fit a 2 pin socket near the euro connector and splice into the motor wires then connect them to the new socket. Put a matching plug on the push pull gun taking care to get the polarity right of the gun motor will run backwards and you're away.
