DAPPH
as dyslexik as I'm daft
Driving inheavy rain onthe M$ a warning light & sounder activated indicating a problem with my tyre pressures, Luckily I was close to my destination where Fizzy has a freight unit.
Fizzy checked my tyres with a TP gauge & we found the RHR wheel was 10 PSI lower than the 35 PSI it should be. Reversing very slowly , Fizzy found I'd got a crosshead screw in the tyre tread .
There is no spare wheel on the EV , I was supplied with an aerosol inflator ;ek stop canister .
Seeing as it is a Motability vehicle I have to abide by their insurance policy terms so rather than pull the screw and pop the inflator can in the tyre I called the RAC , 15 min later the guy arrived , saw the screw , used a battery drill to remove it then popped a reamer in the hole to clean it of any cut wires etc .
Next he used a tool to stretch a 4x4mm or so square profile rubber band so it was reduced to thick button thread dimensions.
After coating the tool pointed end & the stretched band in quick set vulcanizing no heat compound he pushed the device with band into the hole , released the band pressure and withdrew the tool leaving the band in the hole & glue to hold the elastic band in place .
Two minutes later he'd inflated the tyre and I was ready to be on my way ..... with the advice I must not exceed 50 mph & must get th tyre looked at as a Kwikfit tyre service place as soon as possible for it to be removed properly & permanantly repaired otr reneweed as the case may be
MY Oh My, how punctured tyres technology has advance in the last few years . Had it not been possible he would have popped the EV on th trailing axle and towed me to the nearest open repair place or called out KWIKFIT 24 hr. repair services . Had to smile when he mentioned the trailing axle as a set of initials , I asked him what it meant & why call it by the initials ..it's gone Woke .......... no longer allowed to call it a dummy axle nor a tow dolly.
Fixed that myself too.
