Sergei Slovenija
- Slovenija Ljubljana
How to form a hemispherical depression at the end of a punch blank? I probably can’t cope with hardening a raw workpiece; I have neither experience nor a muffle furnace with temperature control. I'm considering using inexpensive hammer drill chisels. As far as I found out, the chisels are made of steel type D2 and similar, but they are already heat-treated.
1) turning on a lathe using cubic boron nitride plates? But I don’t know the turning technique, where you need to move the cutter with both hands synchronously, transversely and longitudinally.
2) copper tool with abrasive? for expansion of a roughly machined hole? I believe that electrical erosion or hardening of a raw billet from a contractor, for such a small order, will not be very cheap.
Rivet hemisphere diameter ~14 mm
