phill d
- slough, berks , England
Hi guys.
well today I had a look at my (new to me) HUGE bench drill.
its an Elliott progress 1 (bench model).
First of all everything seemed fine and dandy, plugged it in to the 240volt ,switched it on and hey presto perfect, smooth running and everything fine.
Then I decide to change the belt setting and put it on highest speed, perfect ran like a dream again.
Then I decide to put it on slowest belt speed as it was on medium when I got it Saturday morning.
When I changed belt speed to slowest running it was slipping bad, first I just thought I had not extended the motor correctly to tension the belt, and "THEN I NOTICED IT", the bottom lip on the smallest bottom v has come apart from the rest of the pulley.
Its a very clean cut and has probably polished itself that way in use before I got it.
I have not yet taken the pulley off the drill yet as i can use it for a couple of things as is tommorow.
Now this is where someone else maybe able to help .
I am needing to know if this pulley could be welded ?
or is it a metal that's not really upto taking a weld ?
its a grey colour and don't look like a quality type metal to be honest, pretty sure its not cast iron.
but maybe looks are deceiving and its a solid steel item ?
I would like to keep its original pulley if possible, this pulley is the one on the electric motor.
and its the very bottom smallest diameter v section.
the one I need to give me the slowest speed for stainless drilling on my outboard engine propellers.
I have an arc welder and access to mig welder too, so if it is a decent steel I could possibly repair it.
any advice on this would be very welcome.
by the way this is my first bench/pillar drill and first time playing around with PROPER DRILLS.
phill
phill
