Whats the best way to attach the hinges to the frame?
I have a router but i'm rubbish as cutting anything straightbest way to trim them down is electric planer.
if you dont have one of them and a router ?
set up a straight edge, set distance from edge and clamp it down.
run router against straight edge to trim the edge neatly.
I have a router but i'm rubbish as cutting anything straight![]()
Even with a straight edge i manage to mess it up.That's why a straight edge was mentioned
Wow and they let you have sharp stuff? Lol
You realise you run the tool against the straight edge not just scribe a line with it right?
Should also work with your plunge router in the absence of a table - just make sure the door is clamped down securely.
Yep id need to weld plates to mount them.you mean like kitchen cupboard hinges.
hmm not much to play with but is doable....
but would take a lot longer in time to do
then just welding some plates on as you suggest for better thickness to tap..
