gasket999
getting there...
- Manchester, UK
Is there a spray or product or technique I can use to stop a mild steel panel from rusting after blasting but before coating?
I am going to need to leave a blasted and subsequently repaired panel in white metal for up to 2 weeks before I can take it to the galvanizing plant. Obviously I don’t want to prime or paint it as it would just need blasting again, but something like a spray preservative could be removed with the degreasant immediately prior to galv.
Obviously the galv process will include pickling in acid to remove rust and scale but I would like to reduce any build-up of surface rust if possible.
Its quite big (1.5m x 1m) so the product would have to be cheap or free – but I’m happy to reapply every couple of days if needs be.
Many thanks.
Many thanks.
