Hey guys,
I just got my Millermatic 140 with Autoset back from service. I bought my Miller because of its reputation for quality and reliability. Then my gas solenoid went out under 2 hours of use. No biggie- maybe i got a bad draw. It sucked not having my welder for 5 days but that's life.
Now I get it back today and start going through some more practice welds.
Within 5 minutes I finish my first 2lb spool of 0.023''. So I switch the contact tips, the travel wheel, and I install the 2lb spool of 0.030'' mild steel wire and pull out some more practice sheets.
At first I like it. But for some reason the gun "jumps" a little every so often. Over the next 20-30 minutes, the keeps happening more and more often. What it seems like is happening is the wire is coming out of the gun but there is no arc. It hit my plate so hard that it not only pushes the gun up but shakes my plate. Now I'm worried something is else is wrong with the internals and the machine isn't creating an arc
As you can see from the pics, the welds get progressively worse using the same technique and settings.
Picture shown in chronological order. Maybe the machine is overheating? I am not getting the warning light.
Millermatic 140 w/AS
Voltage setting 5
Wire Speed setting 55
16 gauge mild Steel
Voltage setting 5
16 gauge mild Steel
see how you get on welding two pieces together.
