Hi All - I am a complete novice to welding but I am looking at purchasing a 160A MMA welder and wanted to know a couple of things before getting purchasing.
The welder requires a maximum 20A rated current consumption which is obviously higher than a 13A standard home socket.
Question 1 - If I get the right plug (EV type 2 male), is there any reason why I cannot connect it direct to my EV charging point which is rated at circa 7.3kWh / 32A? If I can then I don't need an electrician and I can do most of my welding in my driveway
Question 2 - If I did connect the welder to a domestic mains supply (13A) but only ran the welder at 80A (50% of capacity) would it blow the fuse or will the welder only draw 50% of its full mains consumption i.e. 50% x 20A = 10A and therefore not blow a fuse. Tuis would be useful when I want to do on-location welding where I might only have access to a 13A domestic fuse. I appreciate that 80A might only allow we to use a 2.5mm electrode
I hope these questions are not too idiotic but would appreciate any help...thanks
