Mine is a silverline, It works OK. As has been said, great for getting into hard to reach areas. I use screwfix for belts, as they are convenient
I better get mine out today then.I bought the Evolution. Seems reasonably well made. The front roller is a bearing, no rubber, so should be an easy fix when the time (inevitably) comes. 400 watts and variable speed, has enough power for my needs.
Still like a kid with a new toy!
Theres your problemI'd 2nd the Evolution, mine has also proved invaluable. Couple of mates have Black and Decker powerfiles which have also given good service. Interested to see earlier posts about better belts, I do tend to get through them so will be investigating options other than the Silverline ones I have been using to date.
Another tip, if you are using them to grind down welds or smooth metal edges, is to take down any really sharp or pointy bits with a file or sanding block first - if the belt catches it can easily rip immediately. Doesn't apply to those of you who can weld neatly, obviously ...
It's the one tool I wish I had bought from day one on my car restoration. A Dremmel is pretty useful too. With decent cutting discs on (not cheapo Aldi ones; they fracture immediately) they are very useful in a tight or narrow spot.
must do something about that when I find a source of round tuits).
