Badger1bear
If your not on fire, then your too far away
- kent
Hi guys, do any of you use pumice as a blasting media ? Because it’s not that hard Is it any good as general cleaning media or is it solely for cleaning wood ?
can u get a load cheap, if not cant see the point with all the different types of media available . is it just fine powderHi guys, do any of you use pumice as a blasting media ? Because it’s not that hard Is it any good as general cleaning media or is it solely for cleaning wood ?
is it powder or granules. if powder it wont work well in a blast pot and just block up in the valve .if u want to test it get a plastic bottle cut the bottom of it and drill a 6 0r an 8mm hole in the lid and fill it up .if it flows easily without stopping it will work if it bridges and stops it wontI have acquired 1 ton of it and it’s never been used and best of all it was free
worth a try in a pressure pot at 90psiIt’s granules buddy. We are based next to a transport company and they asked if we knew anyone that wanted it. The stuff was not accepted by a customer when made a delivery with it. it’s been dry stored and there appears to be nothing wrong with it
as long as it flows like an egg timer without blocking should work well try some in a bottleIt’s like fine sand![]()
