...made light work after bulking out with the bandsaw.
You don’t necessarily need to use a bandsaw , I just used it bulk it down , you can just use the router and plunge cut it , the same as if you were doing a worktop . 10mm passes and repeat .So you still need a bandsaw to use the router and template.
In the entire YT back catalogue we are being presented with, would it not be good to visualise the cuts he is talking about? In the original post, he says 600+ radius. That is making a semi-circle on the short side of a sheet of ply. Which is quite tight.
I know YT give you some money if you allow ads. in the middle of your content. Have they now started a sub-affiliate scheme where you get $0.001 for every link you post?
as @eLuSiVeMiTe should know you dont need a bandsaw to make a form/templateSo you still need a bandsaw to use the router and template.
I suspect many of them are mothballed. They use a lot of power. CNC lasers tend to be around 1 to 10kw. Many of the water jets are 100kwDo you know anyone with a water jet ?![]()
