Hello need a little help here. I work as a Propshaft Engineer and have to weld tubing almost everyday. We have very little knowlade on welding but we dont really need to know much as the welding is all done with a rotating system. So all we have to do is set the rotation speed possition the torch then use the settings that we have on a sheet for the wire and volts for that specific size of tubing.
But as of late we have had a little problem, our welds have been shocking (see pics)
This happens almost every weld now
. What could be causing this ?
everything is spotless before we weld so i think we can rule that out. could it be dirt of some sort of blockage in the pipe's ?
As i say we have very little knowlage on this
. What could be causing this ?everything is spotless before we weld so i think we can rule that out. could it be dirt of some sort of blockage in the pipe's ?
