Matrixx
- North Duffield
I have a larger than average central heating system, someone has fitted a white expansion tank on the heating circuit ( which is ok for water and central heating) but potable water is usually set at 3.5 bar, where as a a central heating tanks would be 1-1.5bar, I have read that in some cases where the systems is going up three floors or has long pipe runs the pressure might be increased to compensate. but i assume it should set to where the running pressure is , which usually is around 1.5 bar.
I have water coming out of the pressure relief valve , (about a pint per run) on the central heating circuit when running , the pressure is below 1 bar cold and close to 3 bar running, the relief valve it set at 2.5 bar.
I am assuming the tank needs to be drained and pumped up to 1.5 bar ( even though it shows 3.5 bar on the label), and see if it holds pressure.
its not a standard boiler. Am I correct?
