Hello, fellow welders
Ive finally got myself a mig-welder
......................But
Ive equired a sealey super mig 150/5 amp welder. the trouble is the torch on the machine is knacked. But luckly when i picked the mig up its had everything there for a eurotorch conversion.
I would very much like your help in where to wire the eurotorch connector & solenoid to my machine.
On further inspection of the mig & conponents(Hope this helps):-
On the euro torch connector it has what i guess is the gas feed tube a red wire & a black wire. It also has a lug which looks like it should have a cable crimped into it which is on the brass thread of the euro torch connector block.
The old existing torch as far as i can see has to wire a small blue wire going to the pcb & a large black wire which is bolted behind the silver square at the top of the machine.
The solenoid I have is 230volts with 3 wires Blue/Brown/Yellow & Green.
I have added pictures of the mig so you can direct me in the right direction. I will be more than happy to take more pictures if this helps.
Im a complete novice when it comes to wiring so please be gentle!
I look forward to your help, thank you for your time.
The Ra66it
......................ButIve equired a sealey super mig 150/5 amp welder. the trouble is the torch on the machine is knacked. But luckly when i picked the mig up its had everything there for a eurotorch conversion.
The Ra66it
