I've just picked up an unused/old stock Clarke Plasma King 35 for not much money (weighs a ton...), and looking at the spec it needs a 19amp 240v supply. States "do NOT fit a 13 amp plug"
Fairly obvious, but how should I connect it? dedicated radial circuit with a 20 amp mcb? if so, what plug set up should be used, or must it be hardwired to a double pole switch plate?
Anyone else got one? what supply do you use? How well does it cut?
