HI, i have a plasma cutter which is still under warranty until next christmas. It will not cut its recommended clean cut which is 38mm it keeps snuffing the arc out after starting to cut every 2-3 seconds., I have tried most stuff, earth connections inside and out, cleaned the steel and clamped direct to steel being cut, new set of consumables including 2 spare retaining caps, 2 spare drag nozzles 2 of everything. copper strip in earth clamp is succured properly, linked 2 compressors together incase not enough air flow, pressure seems fine, electrical supply to workshop is only 4 years old and is to rated amps for plasma.
