Kent Member Messages 9,992 Location Bowland, Lanacshire,UK Jul 13, 2019 #1 Looking for some heavy wall std tube. Its for spinning targets on a rimfire range. Idealy to be a clearance fit on 8 mm bar centre. Heavier the wall the better and must be easy enough to get and cheap Ideas?
steviec_lj Rust Welding Professional Messages 2,806 Location Barnetby, N.Lincs Jul 13, 2019 #2 Depends on what lengths you need, but could you use some 30mm bar and centre drill an 8.2mm hole? That should be enough for clearance, shouldn’t it?
Wonderweaver Member Messages 281 Location Manchester Jul 13, 2019 #3 Best going to parkers for that they do heavy wall square tube like 100 x 100 x 10 .
colnerov Member Messages 4,625 Location Nr Gatwick UK Jul 14, 2019 #5 Hi, What about gas barrel? - http://www.isg-steel.co.uk/category/gas-barrel-medium Colin
Kent Member Messages 9,992 Location Bowland, Lanacshire,UK Jul 14, 2019 #6 colnerov said: Hi, What about gas barrel? - http://www.isg-steel.co.uk/category/gas-barrel-medium Colin Click to expand... Thanks that was pretty much what i needed in way of a chart
