normspanners
what you are doing is rotating that one pump element, in relation to the rack which controls the three, so as to adjust the amount that pump gives, each will be different, not the timing as the guy in the vid says. it should be set on an injection bench, so that you can see the amount delivered to each injector, is equal.adjusts the fuel delivery amount on that individual pump and nozzle.
it is MUCH easier to remove the 3 pumping elements out of the body complete.
We will double check them of course with the dealer.
