PCMIG 135/09 Gas no gas 30 - 135 amp Power Switch
  1. AngeloC New Member
    4
    Wales, UK
    Hi - anyone know where I can get a new power selector switch for my Powercraft 30- 135 AMP MIG - MODEL NUMBER PCMIG 135/90
    Thanks
  2. eddie49 Member
    Does the switch fail on all 6 power settings, or just one? Have you checked tightness of the screw terminals at the switch?
    The Powercraft brand is sold by Aldi - have you tried contacting their Support department? The welder may still be covered by their 3-year warranty.
    If these suggestions do not provide a solution, I doubt whether you can get the actual part as a spare. However, from this earlier thread:
    https://www.mig-welding.co.uk/forum/threads/no-arc-from-new-power-craft-welder.84399/
    - it looks like the power selector switch is a fairly simple 1-pole 6-way assembly, so a generic replacement should do the job. Make sure that you know where all the wires go before disconnecting them!
    It's often possible to dismantle this type of switch in an attempt to fix loose or burnt contacts, but the usual result of that is a loud ping and a garage floor littered with springs....
  3. 500e
    500e Always buy fire insurance a flood is hard to start
    4,060
    SWest UK
    You didn't find the ball-bearings either then :doh: Did it with a Hoover washing machine program switch It ended with me giving switch & machine to mate who had a LOT more patience than me
  4. AngeloC New Member
    4
    Wales, UK
    Hi
    The MIG is outside warranty and the service centre in the handbook has ceased trading - it was the one in Ireland.
    The welder works on one setting - I think it is 6! The knob it seized in that position - I will attempt to strip it down and see if the contacts can be repaired - anyone done this? Tips?
    Cheers
  5. hotponyshoes Member
    1,521
    Somerset. Uk
    Make a note of where all the wires go before you remove it.
    Strip it down inside a bucket. Take photos every time you take the next layer apart.
    Don't try doing it if you are I a bad mood or short on time. Have a desk light set up so you can see what you are doing.
    Odds are you won't be able to replace the burnt bits any way unless it's just a spring that's snapped or you have the patience to make new bits for it.
    They are easy enough to get replacements for or if you can work out the wiring you could just replace it with some cheap flick switches. You might even get away with a low, medium and full power if you don't use all the settings anyway
  6. AngeloC New Member
    4
    Wales, UK
    Now that is good advice. I will give it a go in the next couple of weeks - it’s jammed so perhaps it is a spring.
  7. 500e
    4,060
    SWest UK
    :laughing::laughing::laughing:
  8. lundtang Member
    71
    Denmark
    I have had succes with repeated flooding with wd40 while wiggling on a 10 position 6 deck switch on an Esab that had stuck on one power setting. Might give that a go before taking anything apart ?
    AngeloC likes this.
Advertisements
