PCB repair replacement for Sealey Supermig 185
  1. Another Useless Welder New Member
    10
    Taunton, UK
    Turned on welder to do some welding today and the wire feed just started running and would not stop.
    So after reading the forum i suspect it is the pcb relay welded together. I have removed the pcb but no removable cover on relay to check.
    So advice required on getting repaired recommendations or replacement.
    Info on pcb - electronic Services snc cod 114306, maggio2004 ord.90/ 9054 (Italian I think)
  2. mike 109444
    mike 109444 Member
    4,296
    uk Bristol
    Try metering between the "common" connector and the "NO" (normally open) you should see an open circuit if it is ok. If it is as you suspect welded closed then it will be a dead short. Then see what printing is on relay to be able to look it up.
  3. Another Useless Welder New Member
    10
    Taunton, UK
    Metering between the "common" connector and the "NO" (normally open) I get no beep on my meter so an open circuit? and the relay is not the problem?
  4. Seadog
    Seadog Forum Supporter
    6,972
    NE London - UK
    A sticky switch in the torch perhaps?
  5. tom2207 Member
    2,503
    uk northern ireland
    try it with the torch disconnected ,, rules out the switch ,,
    boards are next day spares , had a few of them in the last few years ,, I think some one does a repair service on them , ive just put in new.
  6. Another Useless Welder New Member
    10
    Taunton, UK
    Tried torch disconnected, so ruled that out.
    Boards are next day spares, from where, would be nice to know.
  7. tom2207 Member
    2,503
    uk northern ireland
    sealey , number off the interweb , I had a welder pack in at three on a mon afternoon , and had the board in it and going again by lunchtime tues , very good service from Sealey
    Technical Hotline. Tel: 01284 757505. Fax: 01284 ...
    a111r and Shedendman like this.
  8. Another Useless Welder New Member
    10
    Taunton, UK
    Many thanks for everyones help, I'll get another board Monday
    tom2207 likes this.
  9. tom2207 Member
    2,503
    uk northern ireland
    Sealey may not be EWM or Fronius , but its their spares back up that gets them a lot of kudos.
    A working Sealey is still better than a broken EWM.
    a111r and 500e like this.
  10. a111r Member
    888
    London
    Plus you'll find a motor factor locally that'll order in the bits.
    Sealey's spares web page is well out of date, and there's P&P to add on, but much of their stuff is still very reasonable.
    tom2207 likes this.
  11. tom2207 Member
    2,503
    uk northern ireland
    I just rang them direct ,, cred card and parts were dispatched same day. no refer to the dealer etc etc etc.
    a111r likes this.
Advertisements
