hi brokenbiker , whats the dutycycle like on the parweld machine , is it fan cooled
I haven't tried the esab but I've got the parweld XTI160 it's it's fricken awesome.
I'm used to using the old buzz boxes with the twist handle ampage.
The parweld is a fantastic little inverter welder, when my workshop is built in a few weeks I'll be investing in the lift tig gear for it.
Can't wait to try the lift tig function if the stick function is anything to go by.
I've only had the stick not strike up on the first go about 4 or 5 times and that's it.
ESAB Every time!!hi, i am in need of a new arc welder , a.s.a.p
which inverter do you guys think is best ,either the pareweld xti 160, or, the esab buddy arc180 inverter
all help to this question gratefully recieved .
thanks
Why?
Is it so much better?
The things to look at when comparing such machines;
1. Duty Cycle
2. Voltage tolerance
3. Ability to work with extension leads (either workpiece nad electrode holder or mains lead)
4. Open circuit voltage (higher will help to run different types of electrodes, eg 7018, 6010, 6011 rather than just standard 6013)
5. Hot start function
6. Warranty terms
7. Price
8. Actual manufacturer
9. Back up
Not necessarily in that order, others may add more too.
Duty Cycle of Parweld is 25% @ 160 amps and 100% at 80 amps, not as mentioned above! and OCV is 60v (low) so be careful (though maybe you have decided already?)
Hope this helps
Regards
6 Milli
Afew subtle differences between them like max current, colour and the company backing them but otherwise they are the same units.
Depends what your welding, yes if your just doing the odd repair or small project in the workshop than you are unlikely to exceed the duty cycle but if you are fabricating heavy steels onsite in full sun than you will want a decent duty cycle if you don't want to be frustrated.how often do you run a stick welder at 160 amps? and if you do run one for long periods where the duty is an issue then you would be using a much bigger machine anyway so its still not an issue.
i can tell you now it will run 3.2 rods at 120-130 amps all day long without even thinking about cutting out
And it won't!!6013 and its not cut out on me once yet
And it won't!!
I think the pcbs are designed to fail first. (Joking by the way)![]()
