Thanks, I use a bin type incinerator, it does a job but been thinking of getting an oil drum, the rocket stove look great plus the fact it has no bottom so can kick it over once cool and spread the ashes.19kg
to give you an idea what ive done with it
ive had the base of it glowing orange
the barrel type
theres very little ash when done burning, a shovel load to get rid of when doneThanks, I use a bin type incinerator, it does a job but been thinking of getting an oil drum, the rocket stove look great plus the fact it has no bottom so can kick it over once cool and spread the ashes.
But I also like your propane bottle on its stand and it will be heavier.
Come rain or shine my property catches the wind, ( even on a windless day ),I've even had the bin blow over once while on the go.![]()
Looks like a beer keg to me.What size propane cylinder is that @gaz1?
That wasn't in California, was it?I eventually ended up making a rather bigger bonfire one evening, and that finally did the trick…..little bits of glowing red paper floating all around the neighbourhood, good job it was dark.![]()
I read a great book about the master forger Charles Black.I tried water years ago, a 8” stack of old bills and paperworks I’d collected over the years, so I dumped them into a tub of water to let them turn into mush,…. except they didn’t, they stayed as perfectly legible sheets of paper.
So I took them out and drained them, thought I’d burn them in a small bonfire. Except they don’t want to burn, unless screwed up in a ball several sheets at a time.
That was the first shredder I had so many years ago and it was brilliant, shredded anything thrown in it and had the reverse feature.I use this fellowes unit model w-4 got it from an auction for £5 has cut everything I’ve thrown at it including some single wall cardboard boxes. Pretty compact sits under a desk nicely. This has probably been superseded by another model now but I’d look at other fellowes units for sure.
