JonnyAlpha
Hi;
I have had answers to most of these question in bits a long while ago but just need to refresh my understanding.
I have spray the underside of my Mini with Jotun 87 some of it was done a year ago (under the main floor) the most recent was done a week or so ago (under the front arches.
I am no about to spray the inside and outside of the car, the inside was part bare metal and part original paint. The bare metal was rattle canned with U-POL Acid Etch to stop it rusting a couple of months ago and the original paint has been flatted down.
I have an FMT 3006 LVLP Gun with 1.4 and 1.8 needles / nozzles (FMT4007 Kit)
My recent epoxy came out a bit wavy / dimpled possible because the pressure was to high?
Questions:
1. What do I key the Jotun with ready for spraying on U-POL gravitex Stonechip and then celly top coat?
2. What tip should I use for the Lechler Epoxy 1.8mm?
3. 10% or 20% thinners for the Lechler when spraying
4. Is the thinners ratio for cellulose 1:1 i.e for 300ml of paint I need 300ml of thinners?
5.What pressure should I have at the gun for spraying the Lechler?
6. What pressure should I have at the gun for spraying Cellulose?
I sprayed Jotun and the Celly successfully some time ago and remember I had some trouble getting the pressure correct but never wrote down my setup!!!
I am running a line from the Compressor to a second regulator and then a short line to the gun, I may change this slightly this week by building a water trap using copper pipe but then a short line will run from the compressor to the water trap inlet and there will be another regulator at the water trap outlet, then a longer line to the gun from the garage to outside (about 10m)?
What pressure should I set the main regulators at the compressor and at the end of my main line before the line to my gun, I understand that there will be a pressure drop dependent upon the line length?
I am using these Spray Gun Pressure regulators which seem to be a nightmare to set, when I pull the trigger the needle does not stay steady and shoots up to 90psi?
Questions:
