and all calls are recordedI asked my insurers about the cost "if" I was to obtain oxy kit and they said they would class it as commercial premises so lots of beer tokens, told them I wouldn't bother![]()
You've more chance with the sky falling on your headI am concerned that if I get oxy acetylene and store it at home, I run the risk of it exploding somehow and blowing up my house and possibly my neighbours. How likely is this? Is there a safe way to store the bottles? Thanks.
Long gone but when I had bottles I kept them outside - without hoses etc attached
Probably true for most people especially the guy sitting next to it!I’ve only seen one in my lifetime
It came from a commercial vehicle workshop maybe 1/2 mile from my house as the crow flies, I remember the fire. The acetylene bottle was displayed for years at Fowlmere Engineering who had supplied the gas bottle to the workshopProbably true for most people especially the guy sitting next to it!
and all calls are recorded![]()
Only when it suits though. It will have been "recorded over" if it's in your favour.
BOC manufactures it near Immingham.i dont think its made in uk anymore
Can't weld with propylene, and it's still way more expensive than propane.You should consider Propylene instead, its somewhere between propane and acetylene heat wise, but slightly safer than acetylene,
But the biggest advantage is you can get it in rent free bottles, along with the oxy, I get mine from SGS gas, pick it up from my local motor factors
Ah ok, I have only been welding lead with it so far, havent really looked at welding or brazing with itCan't weld with propylene, and it's still way more expensive than propane.
Given it's rarely if ever ultimate flame temperature that's the issue, if I didn't need acetylene for welding, I would stick to oxy-propane.
A bigger nozzle and a little more propane when needed is much cheaper than using an expensive gas.
For lead welding, I can see the advantage of propylene, the big fat propane flame profile would a tremendous mess.Ah ok, I have only been welding lead with it so far, havent really looked at welding or brazing with it
we have oxy propane for cutting and heating on the farm too, it works great, and like you say, is a lot cheaper!
So really, it doesn't.It will kinda weld steel (it's hot enough), but produces incredibly brittle welds (hydrogen embrittlement
Exactly, you will produce a "weld-like-joint" that snaps or fractures easily.So really, it doesn't.
An acetylene flame actually produces an inert area within the flame that acts rather like gas shielding on mig/tig.
Or so I read somewhere.
