Shaun Henry
- Fife
Weather shield is probably the best for outside recoat is about 5 years.
I done one and redone it 8 years later. It's that good. In a high fungus area from the distillery
no they snap off in osbjust use drywall screws cheap and fast enough. if its inside any paint will do unless its going to get damp. if it is use oil based paint and primer
suppose to b 10 years!Weather shield is probably the best for outside recoat is about 5 years.
just stick them in with an impact gun and they don'tno they snap off in osb
yeh its good stuff dont uite last ten years on facias and soffits but well worth the dollarsMy mistake just checked before your reply. Yip 10 years. Anything external I recommend weather shield.
they do they do, it gets messyjust stick them in with an impact gun and they don't![]()
Which Zinsser product have you been advised to use, as there are several available, used for specific purposes.
might have some of that knocking abot tooIt is Zinsser bullseye 1-2-3 interior/exterior primer sealer and stain killer. Bit of a gob full! No idea if it's any good yet as the tin is still to be opened, probably get around to it in a week or so after this chicken shed is finished....
put the membrane over it if you have time, but i have had it on the green house roof for 6 months nowHow durable is OSB in the rain? If I'm cladding a shed does it need protecting from the elements immediately it is put up, or is it water resistant for a while, few days etc?
i used the cromar membraneWhat membrane did you use? I'm just about order some screws from Screwfix, so may get the membrane delivered at the same time.
