I think you’ll find the head on the ratchet side too big from what you’ve said
theres a socket with a built in extension available especially for land rover prop nuts , they look nasty , black and spindly but once you own one , theres no turning back , the newer stuff is in euro torque thoughI got a few imperial ones, the 9/16” is a gem on landy prop shafts. Like most on here I have also butchered a few cheap spanner’s for the odd ball job, a dab of oa heat and a twist works well.
Bob
View attachment 513510View attachment 513511
Problem with socket cap head screws, especially black ones, is they rust well with the influence of the heat. Come a few years time, now they are a real pain to get back out. If you are regularly removing them, in a race car for example, they are excellent.Going back to the original problem, would it be possible to leave two studs that are the easiest to access to hang the manifold from, then remove all the others and replace them with Allen head cap screws?
the very one
That's the same as my Stanley ones by the looks of it.
same as snap on , who I think own Facom these days ,, Ive had a set of these for years and they are handy in some situations , they work way better than they look like they ever would
This is an example of what I mean -
When in place there is no room to fit a ring end of a spanner in between several of the studs and the tubes:
Only cheap, thin ring spanners fit for the loosening or final tightening which is fine in itself but imagine this in situ and a power steering box 3 inches from it. Its small turns at a time for a very long time to get the nut off.
That manifold is a work of art!
Equal length headers I assume?
Will you get it ceracoated or wrapped while you have it off?
Looks simple enough, thin out the ring end of a combination spanner to slacken off and nut run it off with one of the facom/ snapon spanners. Seen a lot worse.
Bob
Wheeler dealers normally remove the whole engine and do any work on the bench. Might have been quicker and get a bit of heat and cleaning up on the required bits.
Mind don't believe they can take out an engine, rebuild and replace it, perform a suspension upgrade as well as a brake refurb in 20 man hours![]()
