Having had a little time to myself this morning I did a little experiment to see how the output voltages on my mig are affected when the machine is under load, i.e actually welding.
This was just to satisfy my curiosity but I thought the results might be interesting to have on here too
The machine specs are Portamig 361, 40-360 amp, 17-46V
I first tested the open circuit voltages (OCV) using a voltmeter set at 200V DC with the positive lead connected to the contact tip using a crocodile clip and the negative probe clamped in the earth return clamp.
I then tested the voltages under load using the same method making sure the negative lead of the multimeter was contacting the plate I was welding on.
Pressing the trigger gave me the following readings;
(C,F = coarse and fine settings, figures on the left open circuit, on the right under load)
c1,f1 - 16.7, 11.0
c1,f2 - 17.4, 11.9
c1,f3 - 18.2, 13.6
c1,f4 - 19.1, 14.7
c1,f5 - 20.1, 16.0
c1,f6 - 21.2, 16.8
c1,f7 - 22.3, 17.5
c1,f8 - 23.6, 18.2
c2,f1 - 25.7, 20.8
c2,f2 - 27.3, 20.6*
c2,f3 - 29.3, 23.0
c2,f4 - 31.5, 24.6
c2,f5 - 34.0, 26.0
c2,f6 - 37.1, 28.0
c2,f7 - 40.5, 31.6
c2,f8 - 44.7, 33.0
As you can see, the voltage drops considerably when the machine is under load, anywhere from around 4V to over 11.
It's interesting that coarse 2 fine 2 is actually lower than c2, f1 and it wasn't a fluke either, I rechecked it to make sure
If anyone else decides to do the same experiment, please be careful, obviously you can't read a multimeter with a welding mask on so you have to set up a shield of some sort to protect yourself from the arc
c1,f1 - 16.7, 11.0
c1,f2 - 17.4, 11.9
c1,f3 - 18.2, 13.6
c1,f4 - 19.1, 14.7
c1,f5 - 20.1, 16.0
c1,f6 - 21.2, 16.8
c1,f7 - 22.3, 17.5
c1,f8 - 23.6, 18.2
c2,f1 - 25.7, 20.8
c2,f2 - 27.3, 20.6*
c2,f3 - 29.3, 23.0
c2,f4 - 31.5, 24.6
c2,f5 - 34.0, 26.0
c2,f6 - 37.1, 28.0
c2,f7 - 40.5, 31.6
c2,f8 - 44.7, 33.0
