cardiffrob
- Wales, Llantwit Major.
Not exactly what I wanted to have to do. The previous owner removed a water elbow from the block and ripped a piece of the water jacket off that will need about 1cm x 1cm replaced to allow the studs to be put back in.
So, Tig braze with SifBronze 8? Bridge the gap fully or Tig in another piece of cast, suitably drilled? Grind out lots or try to keep the gap as small as possible? Just about visible in this pic.
) Just a flat steel plate with a stud welded to it that goes behind where the stud used to go. I think the araldite is only to hold it in position, until you get the nut on.
