Was cutting oak.... you woildnt have known it... may have to get a couple of spares
I resharpen tracksaw blades for rough work. (Breaking down ply/MDF )Sharp blades work wonders … most are considered disposable these days.
Just use one as long as it works ok then bin it
I always use the same blades so o can run 10 blades through on an hour without changing the setup.
I spend 30 quid on 3 Saxton blades for my tracksaw. Couldn't justify that cost.TSC will sharpen a blade for about £11, that's far cheaper than a decent blade!
New blade per kitchen and resharpened at home for the rest
Why spend 30 quid on a single blade il destroy cutting worktops and end panels full of metal. The performance increase/lifespan is negligible with my use.I said "decent" blade.
I'm on the fence about Saxton blades, sometimes they are great, other times not so much, had a wobbly one not so long ago.
lightly touch the tips up on a green stone grinder by hand it works a treatWhy spend 30 quid on a single blade il destroy cutting worktops and end panels full of metal. The performance increase/lifespan is negligible with my use.
Better to have a surplus of new blades to sling on when the best possible cut is required.
Can't say I've had a wobbly blade and I've got a stack of dull blades well over a foot high here.
Got a little sharpening jig in the shed. Makes it easy. Do 10 blades missing one tooth. Reset angle and do the other teeth.lightly touch the tips up on a green stone grinder by hand it works a treati have 3 saws i do it on and a good quality blade on the chopsaw and a table saw just for clean wood
photo ?Got a little sharpening jig in the shed. Makes it easy. Do 10 blades missing one tooth. Reset angle and do the other teeth.
let me know if you are getting shot....Probably have a punt on it. Given the stack of blades I've got will pay for itself.![]()
VEVOR 125mm Carbide Saw Blade Rotary Angle Grinder Mill Sharpener Machine For Wood Working/Table 370W | VEVOR UK
Discover 125mm Carbide Saw Blade Rotary Angle Grinder Mill Sharpener Machine For Wood Working/Table 370W, 5 inch Grinding Wheel and Applicable Blades at lowest price, 2days delivery, 30days returns.m.vevor.co.uk
One I'm using requires fettling.
I will be ordering as soon as my last invoice is cleared. Your welcome to the old one mate. It does the job but a little rickety so could do with fettlinglet me know if you are getting shot....
New one ordered this morning and should be here late next week.let me know if you are getting shot....
