duncans
- leicester
hello I've been on here a short while and what I've learned after advice and reading threads is if you are welding 6mm angle iron to use welding rods not to mig weld 6mm
but this fabrication shop I've been buying angle iron from they are welding these big frames using the MIG welder I can see the mig is 3phase but a bit baffled
only it's Argon, not CO2, which allows spray transfer. The higher the CO2 content, the more arc voltage is needed for a given arc length. So it's very, very easy to get into spray with 5% CO2, but will take a lot more volts with 20% CO2 at the same settings.
